Fuel Pump failure question? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2005, 06:47 AM   #1 (permalink)
View MR2aboveall's Photo Gallery
Unhappy Fuel Pump failure question?
Yesterday I'm driving home from work. I stop at the store and when I go to back out and as I'm pulling back my car stalls. I pull back into the space and go to start it and it won't start. It cranks but no go. I'm thinking it might be the fuel pump but I'm hope it's not. I checked the EFI fuse and it is fine. Is there anything else I should check? Is there a modulator some where (in the distributor) that may be bad? Maybe not giving it any spark? If it is the fuel pump does anyone know how much I'm looking at for the part and labor? Any help would be appreciated.
MR2aboveall is offline   Reply With Quote
Old 08-04-2005, 06:42 PM   #2 (permalink)
View MitchB's Photo Gallery
What you describe is not normal behavior for a failing fuel pump. Electric pumps usually lose pressure for a while before they just stop altogether. In this case, the car drives like garbage, especially under heavy load, because the pump can't supply enough fuel.
Yes, it's an N/A. It IS a 3.0 liter V6 though. Does that matter?
MitchB is offline   Reply With Quote
Old 08-04-2005, 10:11 PM   #3 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998875
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
my fuel pump went out in my '92 N/A. pump's in the tank- I had techs do it .and if i remember correctly, they had to pull the tank. and with parts and labor it was $225.00- ten yrs ago!!! so more than likely it will be more by now..
The Jedi Speeder at CarDomain
Old 08-05-2005, 04:58 AM   #4 (permalink)
View YouTellMe's Photo Gallery
I think its more likely ur distributor gone bad? u might wanna check if ur dizzy is still giving an output.
YouTellMe is offline   Reply With Quote
Old 08-05-2005, 06:33 AM   #5 (permalink)
The cars have diagnostic connectors. Use them!
