wastegate type?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-02-2005, 03:19 PM   #1 (permalink)
View danboy's Photo Gallery
wastegate type??
hello
does anyone know if our turbos,91ish,have internal or external wastegates?because i brought a hks evc III after reading the threads bout how rubbish manual controllers are!and im not sure what type wastegate i need it to control?or if i need to set it up as a dual port type wastegate to?because i see theres two ports on the back of my wastegate....does anyone have any advise please??
Thanks
p.s.iv said before im gona put a picture of my car on,so here it is,nothing fancy i know,but i still think it looks better than the ferrari behind it!
danboy is offline   Reply With Quote
Old 08-02-2005, 03:25 PM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
The factory turbo on the MR2 has an internal wastegate that is controlled by an actuator. What you are seeing with 2 ports is NOT the wastegate. It is the wastegate actuator.
The "dual port" set up is for people running external wastegates.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 08-02-2005, 05:07 PM   #3 (permalink)
oh ok,thanks,you are very wise jekylandhyde!
Old 08-03-2005, 09:36 PM   #4 (permalink)
View tater_tot's Photo Gallery
well since someone has waste gates brought up.. i was wondering if anyone here has shimmed theres like most do on the mkiii supra
tater_tot is offline   Reply With Quote
Old 08-04-2005, 05:17 AM   #5 (permalink)
I love Cin
What does "shimming" a wastegate do for you?
I have never heard of anyone in an MR2 doing this.
Old 08-05-2005, 03:35 PM   #6 (permalink)
heh i guess not then... "shimming" it is basically taking like a total of four washer and undoing the 2 bolts to the actuator and putting the 2 washers per bolt and bolting back down. its a cheap and semi safe way of gaining some boost. reason i say semi is bc some ppl have run it like tht for a couple yrs and their wasegates and wastegate diapghram stay fine. depends on health of turbo and wastegate. i was just curious if anyone had tried it on a mr2 ct26. u prolly gain about 2 psi.
Old 08-05-2005, 09:07 PM   #7 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
Isnt that what adjusting the gain on an EBC does? except..... ummmm... safely?
Function over form.
Drifting Dane is offline   Reply With Quote
Old 08-05-2005, 09:13 PM   #8 (permalink)
overall yea
Old 08-07-2005, 09:12 PM   #9 (permalink)
Foul Weather Drifter
View SpeedballTrix's Photo Gallery
"Isnt that what adjusting the gain on an EBC does? except..... ummmm... safely?"
SpeedballTrix is offline   Reply With Quote
Old 08-07-2005, 09:54 PM   #10 (permalink)
spin turbo hammy... SPIN!
Hamsterman's Avatar
iTrader Score: 30 reviews
View Hamsterman's Photo Gallery
on my camry - we had to move the WGA to clear the mani and block, so now my WG actually is "set" to 5psi... it is kinda cool for a 5s turbo - since it makes it safer for daily driving boost, and then the greddy profec can be set higher if desired
Lick first... ask questions later
Hamsterman is offline   Reply With Quote
Old 08-08-2005, 03:07 AM   #11 (permalink)
^awesome that you managed that. i totaled mine b4 i could do a swap or attempt turbo. what all did you do. and its not completely unsafe unless ur puttin like more than a reasonable amount of washers per bolt. like 3 would be the most id go. heh but considering the responses ill assume my answer was no that noone has tried it on a mr2 lol.
