misfire/bogg?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-10-2005, 10:45 PM   #1 (permalink)
johnr's Avatar
View johnr's Photo Gallery
misfire/bogg??
My 91 mr2 under acceleration wether car is in drive or not, misfires and completley bogs out.....then gets going again. When this happens the rpms completley drop to zero and the engine light flickers on.....i have all new ignition wires/plugs/distributor.....anything will help i am stumped....
johnr is offline   Reply With Quote
Old 08-10-2005, 11:03 PM   #2 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
na or turbo?
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 08-10-2005, 11:43 PM   #3 (permalink)
johnr's Avatar
Originally Posted by MR-355-5sfTe
na or turbo?
Sorry it's an NA. An added note is that everything seemed fine before the Alt. was rebuilt, however the battery is charging at the right voltage output by the guage reading. The check engine light is not giving a code, however it does work fine as I checked. I also ensured "all" electronic connections were made. (not loose). The fuel filter was changed 2 years ago. Timing 10 deg as stated.
Like I had stated...When reving..or snapping the throttle at about 3 -4k RPM it (like drops off and die for a second and the check engine light flicks at that same moment.
The distrubutor is about a year old...check cap, rotor and plugs (good) new wires.
If ya got any idea's my friend Thanks
Old 08-12-2005, 03:24 PM   #4 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Have you checked to make sure the throttle isn't sticking?
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 08-14-2005, 01:16 AM   #5 (permalink)
johnr's Avatar
Thanks for giving me something Jekyland hyde, I checked the throttle body and cable...and it's not that.
The engine will not have the above thread problems every time I step on the trottle (just every 3rd or 4th or 5th time)?????? The flash of the engine light is what really wants me to think its on the electronic, but I can't put my finger on it??
Old 08-14-2005, 01:31 AM   #6 (permalink)
View blaster919's Photo Gallery
dont know of this will help but when i bought my 91 turbo the guy i had bought it from had taken the lid plate off and the distributer had rusted and was giving bad spark. It was giving me the same symptoms as what uve stated. good luck.
blaster919 is offline   Reply With Quote
