whats up fellas.
I am now currently shopping for my perfect turbo, im not really familiar with all the turbos out there so anyone with knowledge of aftermarket turbos please guide me in the right direction
So im planning on leaving the bottom end stock since im only shooting for 350-400hp, mild build on the head such as valves, spring, retainers, shimless followers,
cam gears(stock cams), and mild port and polish then 3 angle valve job to top off the head. As for fuel/management, im going with supra 550cc injectors, adj. fuel pressure reg., braided steel feed/return lines, supra fuel pump, looking for a good fuel rail, and ECU is still undecided.
So what turbo should i go with in this set up(these are just the major things listed).
T3/T4, GT35, T67...? i want the turbo boost threshhold to be at consideribly low rpm, yet i would like it to pull hard through the higher rpms.
thanks
