hmmm, well, this is a compound question deserving of more concise questioning. first of all, if you merely bore a cylinder, it doesn't necessarily 'give' you anything other than a fresh crosshatch when you use a standard or standard overbore piston. if you bore a cylinder then add a higher compression piston, then you have raised compression, still haven't really added any 'volume'. you stroke will more determine that aspect. now, if you stroke and engine, then you're looking (oftentimes) at a change in volume (and i am using layman's terms here) and then gains can be found with the right combination of other parts. also with just the overbore, then one also has to consider the loss of compression due to the entire quench area being changed (no matter how small) and the 'gain' is more seen as a loss due to having to make compensation(s) in other areas.
i assume you're discussing the 3SGT-E, but it applies to most any internal gasoline combustion engine.
