oil light?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-23-2005, 11:19 PM   #1 (permalink)
View tater_tot's Photo Gallery
oil light??
ok so there is this orange light that came on today. looks like oil with some little wavy lines under... what is this... anyone know.. i just put 3" DP and 3"pipe to 3" muffler after the flexpipe.. sry i just dont know what it is... i have been trying to find out what tht light means and havent found anywhere.. all i can say is help
tater_tot is offline   Reply With Quote
Old 08-24-2005, 12:32 AM   #2 (permalink)
no more V-6...
MR-355-5sfTe's Avatar
View MR-355-5sfTe's Photo Gallery
it's either your "low oil level" warning light.... or a "low oil pressure" warning.... check the oil level first... if it's low.... fill it up and see if that helped the light prob.... if that doesn't work check the oil pressure sensor just to the driver's side of the exhaust manifold on the block... it is a circular-looking piece of alluminum with a wire leading to it.
good luck
back to the 4cyl...
MR-355-5sfTe is offline   Reply With Quote
Old 08-24-2005, 01:55 AM   #3 (permalink)
ok so its my oil lvl light and oil is completely full and it still comes on after a few moments....hmmm..
Old 08-24-2005, 12:09 PM   #4 (permalink)
Gameroom cash: $147537
Either broken oil pressure switch/connect or really bad oil pump. You sure its not coolant over heat light?
Old 08-24-2005, 12:45 PM   #5 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
yellow oil light is low oil level....red is low oil pressure......
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 08-24-2005, 03:01 PM   #6 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998875
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
if you car is sitting on an incline for awhile idleing, it will set off the oil level lite.
The Jedi Speeder at CarDomain
Old 08-24-2005, 05:49 PM   #7 (permalink)
well what would the coolant overheat light look like.
Old 08-24-2005, 06:13 PM   #8 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
you should have a temp gauge.
Old 08-24-2005, 11:43 PM   #9 (permalink)
yea i do... thats why i was curious about a temp light. i suppose i shoulda said it was a 91t.
Old 08-25-2005, 10:01 AM   #10 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
I had a bad thermostat awhile back and overheated, I don't recall seeing a light. just the needle buried in the red..
