H*E*L*P (stalling!!) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 08-30-2005, 11:57 AM   #1 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
I've never had any issues with the car like this. It started randomly today. If I start the car, it revs for a sec and dies. If I give it gas, it stays running, but there is a slight vibration that there never was. If I drive the car, when I let off the gas it jerks, and when I press the gas again it jerks.
Not sure if anyone can figure out what I mean, but if you have ANY ideas, please tell me!!
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 08-30-2005, 12:09 PM   #2 (permalink)
Phi
Whine Connoisseur
Phi's Avatar
View Phi's Photo Gallery
Too many possibilties but here are a few things off the top of my head. Perhaps a stuck EGR. Maybe even a bad coolant temp sensor or clogged fuel filter.
Does it happen with any predictability (ie. hot, cold, wet).
What's your maintance record like?
TN Map - Add Yourself
Phi is offline   Reply With Quote
Old 08-30-2005, 12:51 PM   #3 (permalink)
omg jdm
aaron7's Avatar
Fully maintained all it's life. As of a month ago, it has new plugs, wires, cap, rotor, oil, filter.
It has never happened before, but the wet plug thing has... and this is different from that. When I gas it, it revs fine (though a little shaky), as opposed to no power.
A couple days ago I did see it almost to the red line on the temp gauge; another thing that has never happened. I opened the engine cover and heard the overflow bubbling!
Old 08-30-2005, 03:18 PM   #4 (permalink)
omg jdm
aaron7's Avatar
Ok, I just drove it, and it is idling at 600rpm (opposed to the regular 1200), smells like a four wheeler (running rich?) and idles like a truck with a lumpy cam in it! WTF??
Old 08-30-2005, 04:54 PM   #5 (permalink)
View mrseed's Photo Gallery
i'm in the reverse situation! it idles high enough when starting (1200rpm), but as it's warmed up, the idle drops to 600rpm and sometime stalled!
i'm still trying to figure it out, any help would be nice!
mrseed is offline   Reply With Quote
Old 08-30-2005, 05:03 PM   #6 (permalink)
omg jdm
aaron7's Avatar
Also, it does do the wet problem (where you gas it and it bogs out), so maybe a wet dizzy cap or coil? Ugh I have no idea!!!
Old 08-30-2005, 06:14 PM   #7 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
After all this rain we've been getting, it wouldn't hurt to pull your cap off and check to make sure everything's dry.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 08-30-2005, 06:39 PM   #8 (permalink)
omg jdm
aaron7's Avatar
The outside of the cap is dry, as is the whole motor. How would water get in there?
Old 08-30-2005, 08:45 PM   #9 (permalink)
4DMR2t's Avatar
water can get kicked up from underneath, and get in through the seal. It's not air tight.
I'm only suggesting it to you because it happened to me once.
Old 08-30-2005, 10:14 PM   #10 (permalink)
omg jdm
aaron7's Avatar
Well thanks for the tip; I definately will check it out.
Are the coils known to get wet or malfunction like this?
Old 08-31-2005, 04:05 PM   #11 (permalink)
omg jdm
aaron7's Avatar
Brought it to a shop today... turns out I had a stuck AFM. All is well now... $112 later...
Also, I guess I was down 2 quarts of oil, which may have been my overheating problem. Weird thing is, no lights came on and my oil pressure was still decent!
Old 08-31-2005, 04:09 PM   #12 (permalink)
View smoothact's Photo Gallery
Canada
check engine mounts
smoothact is offline   Reply With Quote
Old 08-31-2005, 05:27 PM   #13 (permalink)
omg jdm
aaron7's Avatar
Scratch that. It just started doing it again. Sounds like I need a new AFM... and they are $212 + $50 core at the parts store... and have to be ordered!!
ARG!!
Old 09-01-2005, 06:15 AM   #14 (permalink)
i overtake on roundabouts
View feral4.mr2's Photo Gallery
ever thought about adjusting the idle screw on the throttle body? the idle once warm should be ~900 rpm.
i would be looking further into that, being low on oil will not cause it either.
feral4.mr2 is offline   Reply With Quote
