Mk1's with aftermarket air intakes - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-03-2005, 10:11 PM   #1 (permalink)
View mikeym's Photo Gallery
Gen1 Mk1's with aftermarket air intakes
how many people have aftermarket intakes on their mk1's... how does driving in the rain affect it? i've been kicking around the idea of putting a k&n on mine... but i'm not sure...i have a stock 85 n/a....
opinions?
~mikeym
mikeym is offline   Reply With Quote
Old 09-03-2005, 11:51 PM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
well, seat of the pants dyno says ok. sounds good too. usually, one has to 'trim' the engine cover and then add a splash shield over the cone.
ToyotaTechGeek is offline   Reply With Quote
Old 09-04-2005, 12:28 AM   #3 (permalink)
thanks for your opinion... my friend had a k&n on his mitshubishi and it would stall out the engine cause it sucked in too much air... why is that? and could that be a problem with my car? what does too much air cause?
btw...
i'm doing an engine lid mod as well.. but you'll all see that when i'm finished with it
i haven't seen anyone do it yet... so we'll see it should help for ventelation as well... picking up the lid to start on tomorrow
~mikeym
Old 09-04-2005, 12:55 PM   #4 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
I have a cone on a relocated AFM. Sounds decent, and one site online states a 5hp increase with any cone over the stock restrictive intake setup! Sounds like a lot to me, but it must be true cause I read it on the internet
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 09-07-2005, 12:37 AM   #5 (permalink)
View ScMr2Man's Photo Gallery
I have a 88 mr2 with a K+N cone filter, but it's located in the trunk.
ScMr2Man is offline   Reply With Quote
Old 09-07-2005, 11:47 AM   #6 (permalink)
View TRDMR2MKI87's Photo Gallery
i have an 86 mr2 with my cone rerouted to the air duct on the side of the car and i drive it rain or shine. with no water leaking problems
TRDMR2MKI87 is offline   Reply With Quote
Old 09-09-2005, 02:50 PM   #7 (permalink)
View mr2poweraw11's Photo Gallery
i've seen someone relocated to the bottom of the car, near the tranny i guess, never had a problem with that.
mr2poweraw11 is offline   Reply With Quote
Old 11-24-2007, 10:19 PM   #8 (permalink)
Mister O's MR2's Avatar
View Mister O's MR2's Photo Gallery
Gen1 Mark 1 K&N cold air intake installation
I just installed a K&N model 57-0120 cold air intake on my '87 n/a.
The kit only came with one (straight) silicone hose to attach between the air flow meter and the K&N cone filter.
I would need another hose to attach between the throttle body and the air flow meter.
I only had 2.5" left before the cone filter would interfer with the left rear strut housing.
Instead, I decided to use the kit's hose between the throttle body and air flow meter, then I reused one of the stock elbow hoses (the smooth one with one end larger than the other) facing down.
I attached the cone filter onto the end of this elbow hose.
The filter is in front of the original intake pipe coming from the trunk (I don't know if any air is fed through it at speed). I ran the cold air tube from the kit to feed air to the other side of the filter.
The filter is just above and to the rear of the transmission--facing down.
I don't normally run my Two in the rain (I have another vehicle for that) so I may never know if this set-up will stay dry in the rain.
Frank
1987 Gen 1 MR2 normally aspirated (original owner)
4AGE engine
Mister O's MR2 is offline   Reply With Quote
Old 11-26-2007, 01:08 AM   #9 (permalink)
i overtake on roundabouts
View feral4.mr2's Photo Gallery
bawhahaaaaa... sounds more like your friend didnt hook something back up when he removed the stock air box.
no you wont have a problem. the amount of air into the engine is determined by your throttle body.
look forward to seeing what you are doing.
DIM spec 87 AW11. 4agete powered @ 12psi. aka: the feral.
JDM 89 AW11. twincharged auto powered @ 18psi. aka: lil feral.
ADM 88 AW11 4age powered track beater. aka: vermin.
Diahatsu Feroza II. turbo'd @ 4.5psi sand eater. aka: tufferoza.
feral4.mr2 is offline   Reply With Quote
Old 11-26-2007, 10:45 AM   #10 (permalink)
omg jdm
aaron7's Avatar
My current intake sits under my scoop:
