Originally Posted by Pineapple
It was block off to manage coolant pressure and flow so coolant flow to every part of the head.
Where do you have leak? What's leaking? You got a crack on the block/head? Head overheated and warped?
I hear you and was thinking the same thing about wanting to regulate the flow of coolant but if that was so, why then did they even make passages that need to be blocked off by a gasket. Almost sounds like they found out problems after designing it and didn't want to go back and change after the fact (and took an easier way out).
I have leaking at the gasket interface (head/block). I know that head isn't cracked or warped because I took it into a machine shop and he machined it smooth after making sure it wasn't warped. The block I didn't check but I figured it couldn't warp significantly since it is cast iron (at least that's what I figured but I should probably go out and do the measurements). I didn't do any penetrant inspection for cracks either.
