4agze twin turbo convertion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-13-2005, 11:23 PM   #1 (permalink)
View sabatage's Photo Gallery
I have an old 4agze engine that Im rebuilding with all forged internals and was wondering what ppl thought about ideas for turbos for a twin turbo set up ; I was jus thinking of using the set up off a Rx7tt would these work and what are ideas for other turbos for a twin set up on a 4agze(all forged internals) looking for fast spool and high top end??? Im leaning toward the twin set up off a rx7tt because of ease to get so want thoughts on these for the 4agze??
sabatage is offline   Reply With Quote
Old 09-14-2005, 12:36 AM   #2 (permalink)
Gameroom cash: $134655
why? a larger single turbo will make better/more power....
and why go all forged internals??? the factory gze has forged pistons & crank.... the crank, pistons, & rods are almost perfectly balanced from factory as well......
Old 09-14-2005, 12:45 AM   #3 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
i agree, PLUS the turbo set-up off of a FD is ridiculously heavy from what i remember. AAMOF the FD/LS-1 conversion is perfect because of the LS1 being the same weight (pretty much) as the rotary plus the TT set-up. damn!
ToyotaTechGeek is offline   Reply With Quote
Old 09-14-2005, 01:08 AM   #4 (permalink)
Im looking for a solution that I can get from the local yard maybe a m62 or m90 supercharger my first choice is a gt2871r but hoping to save a lil and get 350 to 400hp.... I know the m62 can put out 10 to 15 psi as I have seen it in miatas whatta u think of these superchargers and what do u think i should do?
Old 09-14-2005, 07:32 AM   #5 (permalink)
someone on MR2OC has done that SC, but IIRC it didn't do that well. maybe the M90 does better. i don't really remember.
Old 09-14-2005, 12:12 PM   #6 (permalink)
thank you for that info i believe the m90 would be too big and not very efficient in the higher rpm's, so I have looked around and believe i will use twin gt15 turbos there good for 220hp each so round 400hp for track and 325-350hp for street whatta u think this setup will perform like?
Old 09-14-2005, 12:55 PM   #7 (permalink)
Gameroom cash: $147537
^Don't think you should add HP up that way. Why don't you put 4 and get 800HP?
Old 09-14-2005, 04:50 PM   #8 (permalink)
Foul Weather Drifter
View SpeedballTrix's Photo Gallery
400 hp in an aw11 would be ridiculous.
I wanna see this =)
SpeedballTrix is offline   Reply With Quote
