Timing not right..HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2005, 12:17 PM   #1 (permalink)
View 93MR2Turbo's Photo Gallery
Hi guys, Im new here and dont know much about toyota. I just bought a 93 mr2 turbo. and the ignition timing is not right, I turned the Dist. all the way and its only giving 5 degree, can someone tell me whats wrong?
Thanks
93MR2Turbo is offline   Reply With Quote
Old 09-15-2005, 01:47 PM   #2 (permalink)
c'mon, anyone??
Old 09-15-2005, 02:54 PM   #3 (permalink)
Gameroom cash: $147537
You need to connect 2 terminal on diagnosic box. There should be a label on hood to tell you what to connect.
Old 09-15-2005, 03:44 PM   #4 (permalink)
where is the diagnostic box? and what does that do?
Old 09-15-2005, 03:48 PM   #5 (permalink)
Put the ECU in diagnoistic mode so you can set idle and timing. Check user manual for location.
You'll have 15deg or more advance if you just check it without connecting the terminals. Also timing is not stable enough to get a good reading. You should put disturbutor back to where it was.
Old 09-15-2005, 04:29 PM   #6 (permalink)
Noobie With A Dream
View mkIImr2lvr's Photo Gallery
Ok...i need to adjust my timing and I have a noob question. The bgb says that you need to connect terminals TE1 and E1 with a SST. What is an SST? Do you just connect those and then check the timing. It then says if you dont' have those connected it will be 12-21* btdc. thanks for any help.
- 2007 Highlander V6 4WD (Wife's DD)
- 1991 Camry DE (My DD)
mkIImr2lvr is offline   Reply With Quote
Old 09-15-2005, 04:55 PM   #7 (permalink)
I took the car to the shop and have the mechanic check the timing for me, he said it has only 5 deg max. He said it could be the timing belt is not lined up right. Is that could be the problem or something else worse could cause that?
Old 09-15-2005, 06:58 PM   #8 (permalink)
View deekay140's Photo Gallery
most likely the timing belt.. dont recommend trying that yourself. take it to the dealer.
deekay140 is offline   Reply With Quote
Old 09-15-2005, 10:16 PM   #9 (permalink)
SST-Special Service Tool, in this case a jumper wire or piece of metal to short the terminal.
Old 09-15-2005, 11:50 PM   #10 (permalink)
Noobie With A Dream
Aww...makes sense. Thanks for your help!
Old 09-16-2005, 12:32 PM   #11 (permalink)
ok thanks guys
Old 09-21-2005, 11:38 PM   #12 (permalink)
Help guys, I went to the shop and opened the timing belt cover but the belt is lined up right, took out the distributor and put everything back together, then the timing is normal again. Drove it around, but the car still doesnt run strong, it won't rev over 5k. They also did a compression test and its good, so every mechanical parts seen fine. Does anyone know whats the problem?
Old 09-22-2005, 06:39 PM   #13 (permalink)
View OEMonkey's Photo Gallery
You previously mentioned not being able to adjust base ign. timing past 5deg btdc bec. the distributor was turned all the way on its notch. How did it fix itself? Are you sure both cam and crank timing marks lined up?
OEMonkey is offline   Reply With Quote
Old 09-22-2005, 06:53 PM   #14 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
When was the last time you replaced your ignition components?? Plugs, wires, rotor, cap... etc. That is probably your problem.
Old 09-22-2005, 09:56 PM   #15 (permalink)
I dont know, I just bought it couple weeks ago.
