Bosch Plugs - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-17-2005, 09:14 PM   #1 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998875
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Bosch Plugs
anybody tried the Bosch +2 or +4 platnium plugs? just wondering. they claim all that much more spark with the extra tips... you guys opinions are definately appreciated and respected- as usual..
The Jedi Speeder at CarDomain
Old 09-17-2005, 10:50 PM   #2 (permalink)
Gameroom cash: $253010
View BDSL's Photo Gallery
Not sure for MKIII.
But for MKII, stick with OEM ignition components.
BDSL is offline   Reply With Quote
Old 09-18-2005, 12:13 AM   #3 (permalink)
Gameroom cash: $134655
for performance, stick with copper core plugs....... the copper conducts electricity better than platinum...... platinum plugs are only meant to last longer. I never sell toyota owners +2 or +4 plugs.....
factory on your car is probably iridium at nearly $100 from the dealer (i'm guessing).
stick with copper NGK's, can't go wrong.
for boost users.... DON'T USE PLATINUM.... they are much more likely to crack and leave bits of platinum in your motor!
Old 09-18-2005, 02:09 AM   #4 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
NGK or Denso only.
ToyotaTechGeek is offline   Reply With Quote
Old 09-18-2005, 11:20 AM   #5 (permalink)
View OEMonkey's Photo Gallery
Prove it!
Plats come recommended fr the factory. OEM denso and NGK for MKII turbos are platinum. I have personally ran denso plats for 5 years @ 15psi w/ no pre-ignition engine damage fr cracking plugs leaving bits in the combustion chamber.
It doesn't matter if your plugs have 20 tips on it. It doesn't mean the spark will jump all 20 ground electrodes at the same time. It won't even jump 2. It'll jump 1, the closest path to ground. That's just the basic law of electricity. And if it does happen to jump more than 1, it still doesn't mean you have a stronger spark.
OEMonkey is offline   Reply With Quote
Old 09-18-2005, 12:37 PM   #6 (permalink)
well, i still wouldn't reccommend using platinums in a boosted motor. It may not have happened, but it can.
i never said it would jump to multiple electrodes. there are multiple electrodes to lessen the fouling of the plug and for them to last longer.
either way, copper is a better performance plug
Old 09-18-2005, 03:35 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
well, I've tried both and and can't tell any difference performance wise. I had heard about the cracking and those tiny tips melting in combustion chamber , so i have been using the copper NGK's. they don't last nearly as long but I feel safer with them. maybe I'm just paranoid.
Old 09-18-2005, 05:12 PM   #8 (permalink)
Try mr2oc.com. You will find more info there. On a relatively stock motor, stick with OEM spark plugs. You can also use NGK copper plugs but make sure they are gapped...however, copper plugs don't last as long.
Old 09-18-2005, 06:47 PM   #9 (permalink)
I think you're talking about iridium plugs. Toyotaspeed90 prolly meant the same.
Old 09-18-2005, 07:10 PM   #10 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Iridium plugs have tiny electrodes and they have a tendency to crack and cause dmage to valves and/or the tops of pistons.
Platinum plugs are completely fine for a moderately modified turbo MR2.
However, you would be hard pressed to find a worse plug than the Bosch's.
Save your money. They are awful.
The best plug to use in the turbo MR2 is the copper NGKs (6097), but you need to change them every 3000 miles or so. Not a big deal since they are very cheap
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 09-19-2005, 01:41 PM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
thats what I've been using. NGK 6097 coppers... and yeah,OEMonkey,you are correct, I had the Iridium plugs. which I stopped using. especially for $38.00/set.. I will stick with the copper NGK's... thanks guys!
Old 09-19-2005, 02:28 PM   #12 (permalink)
Gameroom cash: $147537
+4 works great with 4A-FE. No problem with 5S-FE.
High compression and boosted engine don't like the small tips. They don't carry heat away fast enough and will cause pre-ignition.
Old 01-30-2006, 10:49 AM   #13 (permalink)
View carcatz's Photo Gallery
hey jeykl/hyde what gap would you reccommend for 10psi not really any mods, because I've got 0-3psi and going to replace my cap plugs wires?
carcatz is offline   Reply With Quote
Old 01-30-2006, 11:04 AM   #14 (permalink)
I love Cin
A turbo MR2 should run 11.8 psi stock. Sometimes the ECU will limit you to 7-9 psi.
For stock boost levels, use the stock gap! which is .032"
Old 01-30-2006, 12:31 PM   #15 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
Here is logic to end this +2 and +4 spark plug bs.
Electrons follow the path of least resistance. That means that only one of those electrodes is going to be used for any given spark.
This makes these bosh plugs about as pointless as a bowling ball.
Function over form.
Drifting Dane is offline   Reply With Quote
