PCV is correct (probably, unless you have other unknown issues with the turbo, etc.). You can eliminate this problem, but all the alternatives are "off road use only" since they vent oily vapor to the air. However, if you used one of these methods you should reclaim some horsepower, as you are eliminating a heat source to your intake. It would "probably" also improve detonation efficiency. But the strength of my arguments (horsepower and improve detonation) vary from car to car and are nearly impossible to measure prior to the modification. I have a link to a very sweet method (i.e. a can reclaim with a vent) but I'll have to dig it up.
