4age oil leak HELP!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-25-2005, 12:46 PM   #1 (permalink)
booN
View 86AW11's Photo Gallery
just finished putting in a small port into my AW and there is a SEVERE oil leak! coming from just below the distributor. this is a strange spot, the only thing i can think of is a crack or there is a small hole plugged with a ball. please help!
86AW11 is offline   Reply With Quote
Old 09-26-2005, 12:55 AM   #2 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
www.twosrus.com
you want the kbox dizzy seal kit.
ToyotaTechGeek is offline   Reply With Quote
Old 09-27-2005, 10:58 PM   #3 (permalink)
booN
replaced the o ring on the dist shaft when i put the engine in. the leak seems to be just below the dist but not at the head gasket where i initally though. the leak is SERIOUS with increased oil pressure the leak turns into a constant flow.
Old 09-27-2005, 11:02 PM   #4 (permalink)
the outer o ring or the shaft seal?
Old 09-27-2005, 11:04 PM   #5 (permalink)
booN
the outer o ring, i didnt open up the dist
Old 09-28-2005, 04:21 AM   #6 (permalink)
yeah, thee's the problem, then. remove your dizzy cap and check for oil inside the dizzy/cap. also, did you apply oil to the outer ring when you installed it? if not, that o ring is now useless.
Old 09-28-2005, 06:51 PM   #7 (permalink)
booN
not really that much oil in the cap, just a little residue. i didnt oil the ring first. just got one from toyota today, will have to try it again. do you really think that that much oil could come from the outer ring? or shaft seal?
'05 taco access cab 2wd 5spd 2.7
Old 09-28-2005, 10:44 PM   #8 (permalink)
well, at first, i thought i only had residue also, but even after the outer ring was replaced, i was still killing alternators. after the whole dizzy was sealed properly, alternator has been fine!
Old 09-29-2005, 12:05 AM   #9 (permalink)
booN
alternator? i just cant imagine how this much oil would be getting by the o rings, there is oil RUNNING down the exhaust side of the motor. makes sense though the leak is right below the dist.
thanks for the help, appreciate it.
Old 09-29-2005, 12:15 AM   #10 (permalink)
no problem.
Old 10-02-2005, 02:02 PM   #11 (permalink)
booN
the dist wasnt the problem. the steel ball pressed(?) into a small port just below the dist was leaking oil. weird!
Old 10-02-2005, 02:24 PM   #12 (permalink)
hmmmm...that IS weird...
Old 10-03-2005, 09:17 AM   #13 (permalink)
View xwarp's Photo Gallery
how much oil was leaking?
and where specifically is this "steel ball" inserted?
i have a minor oil leak and am wondering if it is from the the oil filter housing or somewhere near that area.
thanks.
xwarp is offline   Reply With Quote
Old 10-03-2005, 09:24 AM   #14 (permalink)
if it's around your oil filter area, and have already changed both o rings, then inspect your oil cooer lines.
Old 10-03-2005, 09:35 AM   #15 (permalink)
sorry about the lack of info,
last week, i changed the oil filter and noticed alot of oil had dripped onto the exhaust manifold. after driving it several miles, i noticed that there was a leak somewhere still around the exhaust. i then changed the oil cooling line from the cooler to the oil pan as it appeared to be seeping pretty good. the other line was in good shape.
i still have a minor leak somewhere, it is very small, but enough to drip on the exhaust manifold. i suspect it may be the oil cooler/filter housing that is leaking, but can't be for sure until i can get under it after work today.
does the oil filter housing/mount use paper gaskets?
thanks,
bill
