Originally Posted by Flashmn
No it wont, piston rings wont do shit to the valves. period.
sorry, you still didn't understand... if an engine has both wear on rings and valves. and they both leak... or allow leakage of oil and gasses... it is not a good idea to do only a valve job.. and not do the rings.... as that will cause substanial oil pumping past the rings,, as the rings would be a very weak spot in the seal of the combustion chamber...
If you don't believe me, fine...
just gotta stop this here because I went beyond just his tapping noise, into more work..
