the bulbs work right?
j/k!
First off i'd check to see if there is power going to the fog's itself...i know on my 5th gen..before i sold it, one of the fog's was busted...but i had to sand down some of the rust on the housing...and dip it in diet coke...and later it worked on its own....so rust could be the reason for you too...
Since you already mentioned that the fuses are ok, did you rewire the fogs', check the connections to see if there are still tight (been there - done that..my wire came out the second day i rewired my fog's)..then i added electric tape to hold the wife in the drivers sidekick panal....
Good Luck
