Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Creaking when turning right
View Single Post
Old 10-29-2007, 11:11 PM   #15 (permalink)
Puffie40
View Puffie40's Photo Gallery
costadragon220 - How are your driveshafts and axlenuts? Vibration can mean a combination of things: Worn out driveshafts, loose parts, sick wheel bearings and worn out ball joints (Both bottom and tie-rod) (BTW, replacing tie-rod balljoints are cheap. I got mine for $20 each (That is, if you want the cheap stuff))
have a buddy bounce the car while you look around. I would suspect the creaking would be involved with the springs...How is the nut on the strut? did you get a look at the spring boots when (And if) you had them apart?
Puffie40 is offline   Reply With Quote
