Originally Posted by joshdsouza
..............Ive changed the starters and everything else seems fine but whenever i try and start the car the engine wont turn. Itll crank but thats all it does. Ive checked the fuel line. Any help would be greatly appreciated
If the engine cranks and turns over but doesn't start then the starter is fine. I would pull out one of the spark plugs and check for a spark by holding thread end to ground. If you have spark and the fuel is fine you need to check for compression in the cylinders.
