Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - '92 revs, not moving
View Single Post
Old 10-30-2007, 12:19 PM   #4 (permalink)
tashirosgt
View tashirosgt's Photo Gallery
Check your transmission fluid level.
Put the front end up on jackstands so the front wheels are off the ground. Put it in gear and see if the half-axles turn. If they turn at the differential-end and not at the wheel-end then you broke a CV joint.
With the car back down on the ground, check the fluid level in your differential.
tashirosgt is offline   Reply With Quote
