Originally Posted by ebumdude
It took me a while to search for that guy that posted a month ago or so about his stearing wheel being off center to the right about 5 or 10 degrees when he drives straight.
Well, I don't know if anyone was able to help him, I was out of town. But when I got back I noticed mine was doing the same thing.  I took it in to the dealer and found that the "toe" adjustments for the front right tire were out of wack.
They fixed it and all is better. So if anyone else has the same issues, hope this helps.
You may have seen my posting but I've got mine fixed finally. My idiot dealer used 5th gen Camry alignment specs to do alignment on my 6th gen Camry which did not do a thing to remedy the problem. I brought the car back twice for the same problem after the first incorrect alignment and they kept telling me everything was within spec and that it was "normal" for the steering wheel to be pointing at 11 O'Clock position to go stright due to road crown. I finally discovered they used the wrong specs to do alignment on my car and had to point that out to my dumb-ass dealer. After using the correct specs to alignment on my car, it now tracks straight even on crowned roads.
Here are the links to my before and after alignment result sheets.
The first one clearly says for 02-06 Camry.
http://s229.photobucket.com/albums/e...EAlignment.jpg
http://i229.photobucket.com/albums/e..._Alignment.jpg
