Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Air bag light- 5 flashes 98 Corolla
View Single Post
Old 11-12-2007, 01:42 PM   #2 (permalink)
Buurin
Beware of pigs
Buurin's Avatar
Gameroom cash: $296373
View Buurin's Photo Gallery
Originally Posted by 85Hawk View Post
I have a 1998 Toyota Corolla VE and the air bag light stays on. When I jumper the appropriate terminals I get five (5) flashes or air bag code 5. Which part or parts need replaced? How can I reset the system so the air bag light goes off? Thank You in advance for any help,Dave
I don't remember seeing a code 5 in my FSM.
Can you tell us which terminals you shorted? You should short terminals Tc and E1 on the diagnostics block in the engine bay, 20 seconds after turning on ignition. (Don't crank the car yet, lol)
This gets you the current airbag code. If you short them first then turn on ignition, you get past airbag codes after 20s. There's a difference. Get both if possible.
If you have no codes, the airbag light will then blink twice per second constantly.
If you have code(s), from the FSM:
The first blinking output indicates the first digit of a 2-digit DTC. After a 1.5-second pause, the second blinking output will indicate the second digit.
If there are 2 or more codes, there will be a 2.5-second pause between each code. After all the codes have been output, there will be a 4.0-second pause and they will all be repeated.
If there are more than one codes, indication will start from the smallest numbered code.
Read the code again and post back, and I'll tell you how to clear it.
Buy my parts
Buy my other stuff
Buurin is offline   Reply With Quote
