Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Throttle Body Bypass
View Single Post
Old 11-16-2007, 01:21 PM   #12 (permalink)
Gellenole
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
Gen5
Originally Posted by TRD VVTi View Post
That's funny as hell!!! Not one single thing in your post is correct!
Yes, performing the throttle body coolant bypass will net a very small gain. You will never feel it and it might not even show up on the dyno.
Coolant being circulated through the throttle body is to warm it! It's not to cool it. This prevents icing of the throttle body.
When the vehicle is running the throttle body is actually cooled by incoming air. The throttle body doesn't actuallly get warm because it's mounted on a plastic intake manifold which insulates it from engine heat. Being insulated and having cold are passing through it all the time keeps it cool. However, having hot coolant running through it does warm the incoming air charge. Performing the bypass is helpful in keeping the incoming air cooler. You may get slightly more horsepower, but you may also get slightly less fuel mileage.
I have performed that mod on my Formula many years ago and will probably do it to my Camry once I get down south again.
looks like i won't be doing this too =P I'm more concerned about gas right now than ever... last i checked 91 octane is at 3.80 *squint*
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
