Charging system problems - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 03-21-2009, 09:01 PM   #1 (permalink)
View trashtruck's Photo Gallery
I have a 89 toyota p/u with the 22R. I am having a problems with the charging system, I have killed two batteries (1 was new), I have changed the alt still same problem It is over charging 18 volts Please help I can't keep buying batteries. I am thinking a ground problem but dont know.
trashtruck is offline   Reply With Quote
Old 03-22-2009, 11:14 PM   #2 (permalink)
View 54Toylocker's Photo Gallery
You probably have a wire that is grounding the field on your alt. Check your wireing harnes betwene your alt and the regulator cut the wire loom off and check the wires inside.
54Toylocker is offline   Reply With Quote
Old 03-23-2009, 12:54 PM   #3 (permalink)
Stumped
I was told the regulator is in the alt, but dont know. I can tell you there only the ign coil is on the drivers side where the wire loom leads, also splits and goes around the radiator to the other side. where are the grounds to the eng and chassis?
Old 03-25-2009, 11:16 PM   #4 (permalink)
Sorry You have a internal regulator. You might have goten a bad alt to replace the old one. Take it to your local Checker auto parts and thhy will ge able to check (for free) and see if it is bad. I got two bad regulators in a row from a parts store.
Old 03-26-2009, 06:01 PM   #5 (permalink)
The truck will not start now I think it fried the coil, turns over good but won't run. Gotta go to the parts store for that, will check the alt while there. Thanks.
