22r misfiring - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 08-23-2009, 11:19 AM   #1 (permalink)
View srodgers's Photo Gallery
22r misfiring
I have a 90 hilux with a 22r engine. It misfires if I drive it cold and leave the clutch out going down a hill. Once warmed it doesn't misfire. A friend suggested I adjust the timing, and I did, but still the same problem. The friend said that since the timing chain has some slack in it , I might try to adjust the timing beyond the factory recommendation 0 tdc. Would appreciate greatly any comments from people who've had the same problem with their 22r.
srodgers is offline   Reply With Quote
Old 08-25-2009, 10:01 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $547055
View fourwd1's Photo Gallery
I'd look at the choke heater operation.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 09-23-2009, 03:02 PM   #3 (permalink)
4x4 pickup
View Emerl56's Photo Gallery
First check your plugs and wires and make sure there good, clean them if need be. Does it use oil? Maybe it just needs a good cleaning. If your timing is ok when warm then leave it be. (My suggestion, my 89 22r has the same issue but it goes away in about 2 minutes after it warms up.)
Emerl56 is offline   Reply With Quote
