speedometer not working - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 09-14-2009, 03:16 PM   #1 (permalink)
View 93yotaRuck's Photo Gallery
Got an 93 toyota pickup v6 3.0
I just bought the truck and the speedo isnt working, never has since i got it.
So i tried putting a speed senor in and nothing, and tried spinning the gear while it was out to see if i seen the gauge move. Then i put a cluster in it and still nothing. Checked all fuses and even swapped just the speed heads in the clusters. The cluster is electronic and not cable. I'm pretty much at a dead end. Anyone got any suggestions?
93yotaRuck is offline   Reply With Quote
Old 09-14-2009, 03:39 PM   #2 (permalink)
ChipNOreo's Avatar
View ChipNOreo's Photo Gallery
Does your truck have a speedo cable? Maybe try replacing that. Best of luck!
'96 T100 5vzfe, 4X4, Manual
Custom Interior
265,000 mi and counting
ChipNOreo is offline   Reply With Quote
Old 09-14-2009, 04:24 PM   #3 (permalink)
nope, electric
Old 09-14-2009, 10:20 PM   #4 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $547055
View fourwd1's Photo Gallery
Ok, question no
one asked, does the odo or trip counter work?
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 09-15-2009, 04:57 PM   #5 (permalink)
yes everything works except for the speedo
Old 10-05-2009, 06:09 PM   #6 (permalink)
View toyinhawaii's Photo Gallery
Hey ...did U Ever Get It Working????mine Has The Same Problems....i Did All The Trouble Shooting U Did....my Trip Works...i Use To Get Good Readings Sometimes...but Now My Mph Is About 20 Mph Faster Than My Dial Actually Reads,it Bouncing Slightly And First Off In The Morning The Dial Doesnt Even Read Sits At 0..for A While...this Seems To Be A Classic Cable Problem..i'm Gonna Dig For That Damn Thing Until I Find One..even If I Have To S!@# One...what Else Could It Be????
toyinhawaii is offline   Reply With Quote
Old 10-05-2009, 07:24 PM   #7 (permalink)
i have no clue im still trying to figure it out, ive replace the vss in the trans and got a used cluster and still nothing. BUMP.
Old 10-26-2009, 10:22 PM   #8 (permalink)
View zman8537's Photo Gallery
I bought a 1994 Toyota 4x4 Truck. Individual said the speedo does not work. After crawling under truck I noticed it has electronic speedo not cable operated. There was nothing plugged into the sensor at the transfer case. I have searched for an extra harness or wires with no luck. I went to a junk yard and found a vehicle with same setup and the wires went into the same wire harness with 02 sensor, reverse light, neutral safety switch and cut a big chunk out of wire harness. I took it back home and stripped the same harness on mine to see if wires were cut and wires do not exist. I even went all the way up into the engine compartment and with no luck. I double checked engine compartment for where a cable would normally come thru the firewall and it does not have a cut out so I am just about positive that it is definitely electronic. Can you or anyone else give me an idea as to where to look for harness or tell where the wires would go to ? ? ?
zman8537 is offline   Reply With Quote
