Cost for timing chain service - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 09-16-2009, 12:37 PM   #1 (permalink)
View pancakes's Photo Gallery
I may purchase a 1994 2.4L truck (190K miles) and the owner is not sure whether the previous owner has had the chain serviced, and the current owner has not.
1. Should I just look for another truck?
2. If I do buy it, I would attempt to service the chain myself. What is the overall cost to do this oneself? I would probably to the water pump while I'm in there as well.
3. I have changed brakes, mufflers, and water pumps, how difficult is the timing chain service?
pancakes is offline   Reply With Quote
Old 09-16-2009, 03:47 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $547555
View fourwd1's Photo Gallery
If you do it yourself, parts are under $100, unless you need to replace the TC cover too.
Definetly replace the water and even oil pumps while you're in there.
Here's a great step-by-step how to.
http://www.4x4wire.com/toyota/maintenance/timingchain/
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 09-18-2009, 02:51 AM   #3 (permalink)
Supafly
Jayota's Avatar
Gameroom cash: $257565
View Jayota's Photo Gallery
The timing chain job isnt that bad, its just time consuming.
If the the timing guides are worn or bad then it needs to be done..
It took me two 12 hour days my first time. Could do it much faster now...
My prior experiance on the 22re motor was limited to doing the oil pump and water pump...
Cost me bout $200 for a timing chain kit with new cover from engnbldr.com and new rad hoses and such...
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline   Reply With Quote
