Timing Chain HELP - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 10-27-2009, 03:27 PM   #1 (permalink)
View jhobbs72's Photo Gallery
Timing Chain HELP
Hi everyone,
I have a 1995 YO P/U 22re and i have just replace the timing chain water pump and oil pump. So the problem is i can't get the timing right. I know the chain is installed correctly because of pics on other sites and such also i can post pics of the installation i did also. And i've done this job once B4 on another yo truck 22re. I'm at TDC for a 22R or 5° BTDC for a 22RE/REC/RET and installing the rotor at 12 O'Oclock ive already torn it back apart once thats why i have the pics. But the timing won't snyc up. Not really sure how to say this but im either right b4 the timing marks or right after the timing marks. I've moved the dist so many times and it just wont run right. I can drive it with the timing kinda advanced but does not run right no power. well any help would b greatly appreciated. or if u have any other questions for me i will try to answer them..thanks
jhobbs72 is offline   Reply With Quote
Old 11-13-2009, 02:52 PM   #2 (permalink)
Supafly
Jayota's Avatar
Gameroom cash: $257565
View Jayota's Photo Gallery
Are you 100% sure you got the chain on correctly? Did you compair the new and old chain to make sure they were the same??
Can you post your pictures?
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline   Reply With Quote
Old 11-16-2009, 08:39 AM   #3 (permalink)
OLD SCHOOL
xsvtoyz's Avatar
View xsvtoyz's Photo Gallery
pull the valve cover and check the crank is at TDC and the back side of the cam pulley should be a small arrow that goes TDC
THE BLACK PEARL
recent mods: one eyed jack-in-the-box ball
xsvtoyz is offline   Reply With Quote
