thermostat problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 11-05-2009, 04:17 PM   #1 (permalink)
View jlkoko's Photo Gallery
thermostat problem?
I have a mint condition, 1986 SR5 4WD p/u. It's been garage kept and hasn't been run for the last couple of years. This spring I started running it again and ran it all summer and fall with zero problems. Yesterday, here in the cold northeast, the temps were in the 30's. On my way to work (about 8 miles), the truck never really got up to temperature (the needle was barely off the peg). Normally, it is in the mid range. The heater blew warm (but not hot) air. When I left for the day, the outside temp was ~ 55F. The truck ran normal and the temp got up to the mid range. That evening, I had some errands to run; temps were in the 40s. Same thing happened; never really got up to temp. I stopped in a grocery store for ~ 10 minutes and when I came out and started the truck, the gauge was up higher, but not in the 'normal' range. As I drove it the first couple of miles, the needle went back down instead of up. But, after about 5 or 6 miles, it immediately went up tot eh mid range of the gauge and acted fine; the heater blew hot air. This morning, the same thing happened; didn't get up to normal temp but the heater blew warm air. But, when i got close to work, it acted 'normal' and got back up to proper temp.
So, what's wrong.....thermostat....that's what I assume. But could it be a sending unit or just a slug of air? Any thoughts? Thanks.
jlkoko is offline   Reply With Quote
Old 11-05-2009, 09:08 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $547055
View fourwd1's Photo Gallery
Nothing sounds that bad.
Driving only 8 mi may not be enough time to warm up in cold weather, in warmer weather it would be OK.
You could see spikes when the t-stat opens or closes.
If it becomes a problem I'd start with the t-stat, simple and cheap
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 11-08-2009, 10:33 AM   #3 (permalink)
OLD SCHOOL
xsvtoyz's Avatar
View xsvtoyz's Photo Gallery
you can always use the farther north trick and partially block the radiator with cardboard or something else easily removable.
THE BLACK PEARL
recent mods: one eyed jack-in-the-box ball
xsvtoyz is offline   Reply With Quote
