Fan/Blower problem - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 12-16-2009, 08:49 AM   #1 (permalink)
View alba123's Photo Gallery
Fan/Blower problem
I have a problem with the fan on my 93 hilux...can anybody shed any light on the problem? The fan works fine when wired directly to the battery. First question: When I turn the fan switch on I get a reading of 12 volts going into the relay and about 10 coming out....is that voltage drop normal/correct? seond question/problem: when I plug everything in(or if I dont plug in the resistor) i get the 10 volt reading at the wires going to the fan....but as soon as I actually connect it to the fan the voltage drops to zero. Any ideas what would cause this? cheers
alba123 is offline   Reply With Quote
Old 12-17-2009, 01:01 AM   #2 (permalink)
Supafly
Jayota's Avatar
Gameroom cash: $257565
View Jayota's Photo Gallery
Try replacing the relay.
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline   Reply With Quote
Old 12-17-2009, 04:16 PM   #3 (permalink)
That did the trick
That did the trick. Took the relay cap off afterward and was coroded inside. cheers
