22re noise from engine - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 02-18-2010, 04:42 PM   #1 (permalink)
View matrix30's Photo Gallery
hi my truck just start doing a ticking noise comming from the front of the engine the noise is very noticeble a idle the truck got 300 000 km maybe the timing chain ? sould i stop driving it ? what is the first thing to do ?
help will be appreciate
thanks
matrix30 is offline   Reply With Quote
Old 02-18-2010, 06:29 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593755
View fourwd1's Photo Gallery
An easy way to check the TC is to pull the valve cover. The TC is right up front, grab it and pull, the slack should be minimal. Also grab a flashlight and look down at the guides on each side, they break.
The TC needs replacing every 100K or so miles .
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 02-21-2010, 03:44 PM   #3 (permalink)
View detroitgear's Photo Gallery
i agree with fourwd1 it sounds like it could be a TC and if it turns out to be that I would go with a geared TC the next time and you won't have to worry about that problem again
1985 Straight axle SR5, 7 inch lift, 22re bored 40 over, 38.5 boggers, 5:29 gear ratio, detriot lockers front and rear, headman header
detroitgear is offline   Reply With Quote
