85 Check Engine light - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 02-21-2010, 03:28 PM   #1 (permalink)
View detroitgear's Photo Gallery
USA 85 Check Engine light
Hey I'm new to posting on the fourm but I've visited a few times before. I've got a 1985 SR5 that just got out of the engine shop after I burnt up the motor the last time from running it out of water lol. The motor has been bored to 40 over and the head was shaved some along with the block getting decked. Had a new geared timing chain put on along with a header. The Check Engine light comes on after the motor reaches 3k rpms and stays on. It usually doesn't come on at start up or after idling or slow crusing. I've changed the O2 sensor on the header because some of the wire were split. Just wondering if anyone had any idea what it might be? It doesn't effect the truck I just want everything working right before I mess it up. thanks for any help
1985 Straight axle SR5, 7 inch lift, 22re bored 40 over, 38.5 boggers, 5:29 gear ratio, detriot lockers front and rear, headman header
detroitgear is offline   Reply With Quote
Old 02-28-2010, 09:18 AM   #2 (permalink)
View ttownjoeshow's Photo Gallery
Hi, do a search for checking code, on this site. You can do it your self... you put a jumper in a wire connection and count how many times your check engine light flashes and either post the code or search it. Yours might be different then mine so I don't want to steer you in the wrong direction
3 '86 Toy P/U 4X4... 22R-TE auto stock, 22R-E manual 4" susp 3" body &35's 5:29gears, and a 22RE 4Runner, daily driver.
ttownjoeshow is offline   Reply With Quote
Old 02-28-2010, 08:16 PM   #3 (permalink)
Supafly
Jayota's Avatar
Gameroom cash: $257565
View Jayota's Photo Gallery
te1 and e1 are the connectors you gotta jump.
Use a pen to jot down the blinks of the CEL and go online to decifer it.
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline   Reply With Quote
