I replaced my head gasket months back while i had the head off i had it resurfaced in a shop to clean it up........ got everything put back together with no problems..... a few months after that with no problems...... while driving to oklahoma (made a few trips within the time) it started overheating again.... didnt no what it was i got my exhaust pipes replaced and co2 sensor replaced(needed to be done anyway) it stoped overheating for a couple days until i was driving back to missouri and it started overheating again......
i stoped driving it for about 2 months then when i was back for christmas i started her up.......... no problems...... the entire weekend until i was headed back to oklahoma again it started overheating again..... i replaced the fuel injectors and fuel filter but still overheating....... i had a compression check done and it is pretty high as far as i can tell..... its a straight 4.... 22RE..... running about 200 in each cylinder...... does any1 have any ideas?? next step if nothing will to replace the head.... but the is $$$$ i dont have........ any suggestions or info would be much appreciated thank you much
