gas pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 04-18-2010, 06:45 PM   #1 (permalink)
new guy
View tonyy's Photo Gallery
gas pump?
Okay so I have a gas leak, the leak is right were the line comes out of the pump, does the line come out of the pump so i can put a new one on? do i need a new pump?
1990 pickup 2.4, 5 speed
tonyy is offline   Reply With Quote
Old 04-19-2010, 01:35 PM   #2 (permalink)
_________
View sconlee's Photo Gallery
theres a harness the pump sits on so u shouldnt need another one of those if its still working. plus if its your hose you shouldn't even need to pull the pump out of the tank. just drop the tank and if you can cut the hose back and extend it back with a coupling, fuel line hose clamps and more hose. which u can get from a local auto parts store. if its the harness assembly you'll need to pull the pump and find the harness. I checked my local junk yards and couldn't find the right one and ended up finding someone on craigslist who was parting out there pickup.
So to answer your question yes you can safely unhook everything from the pump without having to buy a new one.
sconlee is offline   Reply With Quote
Old 04-25-2010, 09:10 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593755
View fourwd1's Photo Gallery
If you mean where the hard (metal) line comes out and the rubber hose connects, leaking due to rust there is common. And replacing the pickup assy is the solution.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
