Leak behind water pump - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 05-06-2010, 08:29 PM   #1 (permalink)
View ff5455's Photo Gallery
I have an 88 Toyota pickup with a 22re. I replaced the water pump a couple of years ago and had problems with it sealing ever since. I can usually tighten up the nuts holding it on and that fix's it for awhile but now it's not happening. The leak is always in the same spot. I wonder if the water pump has warped or wasn't even straight from the factory. Anybody have any Ideas or have had the same Problem? I'm tired of it. LOL
ff5455 is offline   Reply With Quote
Old 05-07-2010, 02:29 PM   #2 (permalink)
Supafly
Jayota's Avatar
Gameroom cash: $257565
View Jayota's Photo Gallery
Did you buy an aftermarket water pump? Use a gasket? How about RTV?
How hard did you tighten the hardware up? They don't require much torque, they will snap
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline   Reply With Quote
Old 05-09-2010, 10:58 AM   #3 (permalink)
Ya I just bought a water pump at a parts store after my original water pump died. I did use the gasket and RTV. I just snuged the hardware down.
Old 05-09-2010, 11:59 AM   #4 (permalink)
ALSO AVAILABLE IN SOBER
Zembonez's Avatar
Gameroom cash: $620431
View Zembonez's Photo Gallery
The only way to fix the seal is to remove the part and reseal it. Once it starts leaking, tightening it is a waste of time.
Zembonez is offline   Reply With Quote
Old 05-09-2010, 09:57 PM   #5 (permalink)
Supafly
Jayota's Avatar
Remove it and check it with a straight edge, make sure there are no high/low spots.
Then get another gasket and use a VERY thin coat of RTV this time. Then snug all the bolts up.
