screeching sound - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 05-16-2010, 06:47 PM   #1 (permalink)
View knoxtoy87's Photo Gallery
screeching sound
I have a 93 toy pkup 5 spd and recently whenever i press on the gas while in neutral it has a screeching sound coming from the engine. it gets louder as i press harder on the gas. the sound only comes when i press the gas even in 2nd 3rd 4th gears possibly 5th.it even makes noise in reverse. i have headers and i'm thinking that the noise is coming from the gasket to the exhaust?? or could it be transmission?. i have no loss of power, everything runs fine but it's the sound thats driving me nuts. please help. thanx in advance
edit*- i changed the flanged on the headers to the exhaust, and it still has the sound.
knoxtoy87 is offline   Reply With Quote
Old 05-16-2010, 08:28 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $998275
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
Sounds like a loose belt to me.
The Jedi Speeder at CarDomain
Old 05-18-2010, 09:23 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593755
View fourwd1's Photo Gallery
I'm thinking a bearing, maybe alt or water pump or idler pulley.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 08-14-2010, 06:53 AM   #4 (permalink)
View Orhtotist's Photo Gallery
grinding sound
I don't think a belt would be the problem.
Orhtotist is offline   Reply With Quote
Old 08-14-2010, 07:01 AM   #5 (permalink)
grinding sound
I have a very similar sound that is coming from the the front left or front. It's more like a grinding / screeching sound. It's pretty consistant at idle and driving in all gears. I took off the altern. belt it has a tad bit of noise but still turns smoothly. It will do it after you turn the engine off and the engine is winding down. Haven't checked the idle tensioner or water pump. I'm lost, did you ever find out what is was?
Old 08-18-2010, 03:33 PM   #6 (permalink)
Supafly
Jayota's Avatar
Gameroom cash: $257565
View Jayota's Photo Gallery
Using a long metal object (like a punch/drift) use it like a stethoscope to locate the source of the noise.
Place it on the alt and listen (be carefull, alts become magnetic while running), then move to the rest of the accessories.
When was the timing belt last changed, was the water pump changed too? If you know, what brand parts were used?
1991 Pickup - 3vze - 4x4 - SR5 - 5sp- 270k.
Currently in street DD mode
www.cardomain.com/ride/2572486
Jayota is offline   Reply With Quote
Old 08-28-2010, 08:24 AM   #7 (permalink)
It was the clutch fan! Coulding believe that would make that much noise!
