fuel injection to carb. - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 06-17-2010, 02:51 PM   #1 (permalink)
View vernon's Photo Gallery
how hard would this be to change and what parts would be needed? this is for a 22re 4cyl manual
vernon is offline   Reply With Quote
Old 06-18-2010, 09:58 AM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593755
View fourwd1's Photo Gallery
Intake manifold and carb from an 85 or newer engine to start with. Wiring harness/ECM/sensors would help.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 06-21-2010, 12:30 AM   #3 (permalink)
View 86yotachild's Photo Gallery
anything wrong with your fuel injection parts? im looking to swap from carb to fuel injected
86yotachild is offline   Reply With Quote
Old 06-21-2010, 04:53 AM   #4 (permalink)
nothing wrong with them i was just wondering what the differance was
Old 06-21-2010, 11:58 AM   #5 (permalink)
would you be interested in trading? i just got a new k and n filter yesterday for it
Old 06-21-2010, 12:58 PM   #6 (permalink)
not yet
if i cannot repair what i have i might. i am kinda getting tired of the problem that i am having now though.
Old 06-21-2010, 10:53 PM   #7 (permalink)
what are the problems?
Old 06-22-2010, 09:42 AM   #8 (permalink)
it keeps cutting out when i just try and coast alone. if i am in full throttle or a good pull it is good but if i am just coasting along at any spead it skipps allot.
i have replaced plugs coil d cap rotor button fuel filter
but i still have the skip
Old 06-23-2010, 02:19 PM   #9 (permalink)
out on bail
fourwd1's Avatar
Have you checked the ECM for error codes?
89 4Runner - stock
Old 06-23-2010, 06:46 PM   #10 (permalink)
i tried to
i took a jumper and jumped the to connections in the diagnostic thing and i did not get any codes.
Old 07-03-2010, 03:25 AM   #11 (permalink)
yota44's Avatar
View yota44's Photo Gallery
check the TPS, air flow meter, look for vaccum leaks, check fuel pressure. Don't carb it, that's a step backwards.
Does it have a rough idle as well or is the problem just under load?
88 Toyota 4X4 22re. Comp 260s cam, Pacesetter header, 2 1/4 straight piped, 50 Series Flowmaster, K&N cone filter adaptor, bunch of other useless shit
yota44 is offline   Reply With Quote
Old 07-03-2010, 06:05 PM   #12 (permalink)
yes a little however i really notice the shipping when i just give it a little throttle like if i let off and then press a ltiile but when i am at full throttle i dont notice anything
Old 11-09-2011, 10:09 PM   #13 (permalink)
View stevemiller's Photo Gallery
Egr
try unplugging the EGR vacuum hose and plugging the hose. See if that takes care of problem
stevemiller is offline   Reply With Quote
Old 11-10-2011, 05:03 AM   #14 (permalink)
Where is the egr? I would try anything right now
Old 11-10-2011, 08:09 AM   #15 (permalink)
egr
in the very back of engine , by the valve cover. it has a round vacuum pot and one hose. this did the trick for me. good luck.
