Power Outlets - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 07-01-2010, 09:07 AM   #1 (permalink)
AVIATOR
View CESSNA's Photo Gallery
Power Outlets
I'm new to this forum so am not sure I am in the correct area to pose this question, but will give it a try & hope for some good advice. My 2010 Tacoma has only 2 pwr outlets, both in the instrument panel and both are activated only when the ignition key is on. I would like to make one of them "hot" all of the time like most domestic vehicles cigarette lighter outlets are. I would appreciate suggestions, directions, etc. how to do so. I am pretty handy mechanically and don't care to go back to the dealer for this.
thanks
CESSNA is offline   Reply With Quote
Old 07-01-2010, 09:54 AM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593755
View fourwd1's Photo Gallery
You can but single/dual/triple add-on outlets at any parts store.
Mount it and run a heavy gauge wire to the battery, and be sure to use an inline fuse to protect it.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 07-01-2010, 05:52 PM   #3 (permalink)
AVIATOR
Power Outlets
Thanks for the suggestion regarding getting the autoparts store outlet & wiring direct to the battery (with a fuse). However I was hoping to find out how I could make one of the factory outlets hot all the time. I know there is power to the ignition at all times. Must be someway to tap into that with wiring from one or both instrument panel outlets.
Old 07-01-2010, 09:06 PM   #4 (permalink)
out on bail
fourwd1's Avatar
Basically the same thing. Get underneath, cut the wire, then splice a new one on and run to the batt.
89 4Runner - stock
The Following User Says Thank You to fourwd1 For This Useful Post:
CESSNA (07-02-2010)
