Engine warning light - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 07-27-2010, 09:09 AM   #1 (permalink)
View op910au's Photo Gallery
Australia Engine warning light
I have a 2009 Hilux 4x2 SR 4L Petrol.
I recently installed a reversing buzzer by just hooking it up to the left reversing/ backup light. Works fine for work purposes but sometimes it would be useful to switch it off temporarily...eg leaving a motel carpark early hours. So I thought I would fit a simple switch. Tried to find the circuit and fuse which goes to this by description but no-luck. Eventually by a process of elimination found it was the "ECU-IG & GAUGE".10amp.
Haven't changed anything yet as obviously this goes to the ECU, which I assume is Electronic Control Unit? So may be the computer or emission control. So I have to come up with PlanB and wire the switch more locally to the reversing lights/ buzzer themselves.
However after replacing fuses the "engine " indicator stayed on the dash. Didn't appear to affect any functions whilst driving but the Manual says "Take vehicle to Toyota Dealer". However after a couple of stops and restarts it stayed off.
Should I need to do anything else (apart from not removing fuses indescriminately in the future) ???
Thanks in advance,
Rod
op910au is offline   Reply With Quote
Old 07-27-2010, 07:48 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593755
View fourwd1's Photo Gallery
More than likely the fuse was pulled long enough for the ECU to wipe it's memory. Than after a few trips relearned everything.
Just to be sure you could see if any error codes were stored and aren't related to those circumstances.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 07-27-2010, 11:40 PM   #3 (permalink)
Error codes?
Thanks fourwd1. Excuse the ignorance but how do I check for error codes stored and a listing of what (I assume something flashes??) they mean.
Just an aside...why would they put supply to reversing lights through a critical ECU fuse?? Is there any site where I can obtain an elecrtrical schematic for that model or something close?
Thanks again and regards,
Rod
Old 08-01-2010, 09:23 PM   #4 (permalink)
out on bail
fourwd1's Avatar
You can get the error codes read by connecting a scanner to the OBD-II port.
Here in the states (most of them) you can go to any auto parts store and get it done for free.
The closest online downloadable FSM for your truck that I know of is for a 2007 US model pickup (aka Tacoma).
89 4Runner - stock
