High and Low idle - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 09-21-2010, 09:52 AM   #1 (permalink)
View eggiealta's Photo Gallery
USA High and Low idle
Hi, my dad has a 1990 Toyota Pickup 4x4 4cyl. Every time we drive it in the mornings it idles high, but when we press the brake to stop at a stop light or stop sign, it idles high and low very fast. Once it warms up good, then it stops idling high and low. we have change multiple sensors on the engine block, thinking it could be a temperature sensor but it didnt work. if anyone can Help i would really appreciate it.
Thanks
eggiealta is offline   Reply With Quote
Old 09-22-2010, 08:53 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593755
View fourwd1's Photo Gallery
The reason it fluctuates like that is due to the idle being too high.
Once you cure the high idle problem, the fluctuations will go away.
Have you checked the ECM for any error codes?
You may want to look at the Cold Start Injector, CSI Timer circuit, even the coolant level.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 09-30-2010, 08:47 PM   #3 (permalink)
View elrana's Photo Gallery
This is an age old problem in the 22RE which I have seen addressed in this forum before; conclusion being that what was needed to address the issue was a new Idle Air Control Unit. I recently ordered one and even after installation the problem persists, only with a new twist that my engines' operatiing temp is now higher up to the point that i can percieve the difference in the cab. I dunno....any new suggestions???
elrana is offline   Reply With Quote
