The 3L and 1KZ have different bellhousing bolt patterns, so you would have to swap trannies too.
If the 1KZ does use the R151F trans, it not likely your RF1A t-case will bolt to it, at least based on US versions.
In the US we don't have diesel Toyotas, but the G52 trans/RF2A (almost identical to the RF1A) t-case came with the 22R (carbed) engine. The R151F trans/RF4 t-case came with the 22RET (turbo EFI) engine. The RF1/2/4 t-cases are 21 spline while the RF3 is 23 spline. All 4 t-cases came in either a top shift or forward shift configuration, and are not directly interchangeable either.
 SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
