sticking gas pedal - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 01-10-2011, 09:25 AM   #1 (permalink)
View riderv700's Photo Gallery
sticking gas pedal
hi,
i have a 1992 toyota truck 4x4 extended cab 22r engine. my problem is the gas pedal is hard to press when you first get in truck. once you over come the resistance it is ok. but when it sits awhile it will do it again. real bad in colder weather. i have sprayed lubricant at the point where cable goes into firewall at the pivot points. nothing seems to work for long.
i have looked at the setup under dash and i cannot see why the pedal would stick. has anyone else had this problem? what would be the fix?
thank you
riderv700 is offline   Reply With Quote
Old 01-10-2011, 11:39 AM   #2 (permalink)
30YRTOYOTAPARTSEXPERINCE
TOYOPARTSMAN's Avatar
Gameroom cash: $327600
iTrader Score: 12 reviews
View TOYOPARTSMAN's Photo Gallery
Are you sure the cable is not binding up somewhere where you can't see? Below is a link to an illustration that may help you see how the pedal and cable are suppose to go. Maybe something isn't attached correctly, or you just need a new cable. It wouldn't surprise me if you did.
http://www.mediafire.com/?1itbrk5fixskh81
Originally Posted by riderv700 View Post
hi,
thank you
Gary Smith-Parts Manager
garys@toyotaofnewnan.com
www.ToyotaofNewnan.com
678-854-9601
TOYOPARTSMAN is offline   Reply With Quote
Old 01-10-2011, 12:11 PM   #3 (permalink)
gas pedal sticking
hi gary,
i tried to open link. would not download for me. thank you for your help.
Old 01-10-2011, 06:49 PM   #4 (permalink)
If you email me directly I can send the .PDF directly to you. My email is garys@toyotaofnewnan.com
hi gary,
678-854-9601
Old 05-26-2011, 10:08 AM   #5 (permalink)
View TripleDiamondJon's Photo Gallery
Sounds to me like there's no lubrication left on your throttle cable. I'm not sure if it's possible, but if you can pull the cable out of the shroud, and pump some grease in there, it'll help your situation.
TripleDiamondJon is offline   Reply With Quote
Old 05-26-2011, 10:58 PM   #6 (permalink)
View jetrinka's Photo Gallery
Clean the carb throats. Its likely there is a nice ridge of carbon on them that causes the throttle plates to catch slightly.
jetrinka is offline   Reply With Quote
