You don't mean spur gears vs helical gears?
Why would you be going more than 5 mph in reverse? I think I've found your problem, you're commuting in reverse hence bad mileage.
Your reverse has spur gears, sorta boxy linkages so they make this winding sound which is normal. Spur gears are more for strength. Your forward gears use helical gears because they are much quieter though they have less strength compared to spur gears.
As for the gas mileage, since you first go the truck have you made sure it's up to date with maintenance? How bad is your mileage?
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
