does my 91 pickup need new timing cover? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 05-30-2011, 02:07 AM   #1 (permalink)
View MrHawk's Photo Gallery
Howdy!
I'm a fairly recent owner of a 91 pickup. It has 180000+ miles, and didn't have a timing chain replaced. I noticed on cold mornings whitish smoke that doesn't dissipate quickly, and has a 'chemical' smell to it. I also noticed some white gunk under the oil filler cup, so it seems to me like some coolant might be getting into the engine, right? After thorough research I found out the timing chain in 22REs is a common problem. What's the reasonable $$$ to spend to have a shop do the job?
I am a shade tree mechanic ( I replaced an engine on my 74 WV), and although the directions for the job seem straight forward, I know it would probably take me a while to do this myself. Also, is this an urgent matter, if the truck is not overheating?
Thanks.
MrHawk is offline   Reply With Quote
Old 05-31-2011, 05:04 PM   #2 (permalink)
I just talked to a local shop that specializes in japanese cars, and was told that a broken TC would not leak coolant into the engine, so its probably a head gasket. From what I read on here that sounds bogus to me. Can anyone confirm?
Old 06-03-2011, 11:23 PM   #3 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593755
View fourwd1's Photo Gallery
If the Timing Chain was broken, the engine wouldn't start or run at all.
The common problem with the 22R is the TC stretches with wear and the guides break. This creates a lot of slack in the chain that lets it rub against the TC cover. Eventually it wears a hole thru the TC cover, which allows oil and coolant to mix.
And crank bearings, among other things, don't like coolant.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 06-04-2011, 12:33 AM   #4 (permalink)
Thanks,
Aside from taking it apart and looking inside the cover, are there any other signs/indications that the guides and cover might be shot?
