Originally Posted by MX5Bob
Sorry, should have mentioned, electric fan.
Turns out I have some kind of mystery coolant leak, the kind that doesn't leave any easily seen evident.
I guess the coolant wasn't really full then....
Check your oil for coolant, check compression for possible head gasket leaks.
And put a proper fan back on it. If the electric fan isn't flowing enough air or doesn't come on when its supposed to, you could be losing coolant from excess heat rather than overheating from insufficient coolant.
Belt drive fans are much more efficient than electric due to fewer energy conversions.
