'84 Pickup not running right
Good day all,
I have an '84 pickup that suddenly started acting up. It started and ran normally for about 1-2 minutes then started sputtering and stalled while driving then would not restart and stay running. Managed to get it restarted after sitting for a day but then sputtered and stalled again after 1 minute of driving. The truck would start cold then idle up slightly as normal but then rough idle and barely stay running and was not drivable. No engine codes either. Looked at the vacuum hoses and connections under the hood - no obvious problems. Managed to set the idle a little higher (1100 rpm) and now the truck stays running and is driveable but sputters when accelerating (1100 - 2000) rpms. Anybody run into this problem or have any idea what might be causing this issue. The truck has over 600,000 km and has never had any mechanical issues until now. I would hate to scrap it but am getting frustrated.
Kevin.
