Truck not starting - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 09-21-2011, 03:08 PM   #1 (permalink)
View 86 Turbo Toy's Photo Gallery
Truck not starting
86 toyota truck is not starting. Truck has been siting for about 6 months. Last I started it, it ran great (no problems). Now it will not start. I installed a new battery and I have spark to the plugs. No strange sounds and there is fule in the tank. I thinking its the a fule problem. Could the fule pump be out or wire problems?
86 Turbo Toy is offline   Reply With Quote
Old 09-22-2011, 12:20 AM   #2 (permalink)
Gameroom cash: $425565
View jetwhine's Photo Gallery
86 Turbo Toy,
Yes corrosion is a problem on the older trucks at the fuel pump. Also you can try jumping the fuel pump at the diagnostic port and see if it will start.
jetwhine is offline   Reply With Quote
Old 09-22-2011, 12:46 PM   #3 (permalink)
Thanks, I am only mechanically inclined, but electrical systems is not my specialty. Where is the diagnostic port and what two wires do I cross? Can I disconnect the fuel line from the fuel filter and see if fuel is pumping?
Old 10-28-2011, 09:06 PM   #4 (permalink)
View wizard101's Photo Gallery
truck not starting
try spraying starter fluid down the intake . If it starts then the fuel pump has a problem. It might be a bad ground or a fuse. If it wound start then it could be a timing issue. I hope this helps.
wizard101 is offline   Reply With Quote
