Check again, Toyota never had that ratio.
You probably have 4.10, the most common ratio in these trucks.
Check the axle code at the bottom of the VIN plate, 4.10 is G292.
If it's other than that post back and someone can decode it for you.
And the best ratio for your 33's would be 4.88
And remember, you have to regear the front and rear diffs on a 4X4.
 SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
