Help on 87 Pickup - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Truck, SUV and Van Forums > Hilux (Pickup) Forum
Hilux (Pickup) Forum Dedicated forum for the Toyota Pickup (Hilux)
Old 12-30-2011, 05:46 PM   #1 (permalink)
View mdelk7's Photo Gallery
Help on 87 Pickup
I have an 87 4x4 pickup 22re that is carburated. Drove truck the other day and all was fine, buddy drove truck and ran outta gas. Now after putting gas in and getting truck back running i came to stop and truck just cut out like it ran out of gas again, but it has gas in it. I took fuel line off of filter and put in jar tried cranking several times and im not getting any gas to the filter. Checked all fuses in cab and they are good. Any help would be much appreciated.
mdelk7 is offline   Reply With Quote
Old 12-30-2011, 10:58 PM   #2 (permalink)
out on bail
fourwd1's Avatar
Gameroom cash: $593755
View fourwd1's Photo Gallery
Does it stay running if you give it just a bit of gas?
Did you check the fuses in the engine bay fuse box?
IIRC that's where the fuse that controls the fuel cut solenoid is.
SEARCH before asking
84 4Runner rockcrawler - ARBed 5.29's, 36" TSLs, dual t-cases w/ 4.7 crawler gear, Chevys, 30 spline Marlins
83 p/u trail rig - Buick 231 V6, Weiand intake, Holley 4 bbl, TH-350 auto w/700R4 low gearset, dual tanks ...
89 4Runner - stock
http://www.cardomain.com/id/fourwd1
fourwd1 is offline   Reply With Quote
Old 12-31-2011, 08:08 AM   #3 (permalink)
yota that wont crank
Yes I have checked all fuses even in engine comp. None were bad. I have read some stuff about making sure I'm getting power by jumping the fp to the b+. Can anybody explain where to start on that process? Thanks
Old 12-31-2011, 12:29 PM   #4 (permalink)
out on bail
fourwd1's Avatar
Wait a minute.
Looking back at your original post, you say your engine is a
A 22RE is EFI, a 22R is carbed, which do you have ??
89 4Runner - stock
Old 12-31-2011, 12:40 PM   #5 (permalink)
87 yota
I have 22r not re. My mistake. It is carburated.
Old 01-01-2012, 01:29 PM   #6 (permalink)
View 93BetterThanTheRust's Photo Gallery
Always check the basics first:
Does it have spark? ..does it have gas?
If your can keep it running by dribbling gas in the carb, then the filter, fuel pump or plumbing have a problem.. in that order.
If you're cranking and no gas comes out of the fuel line (good thinking, by the way..) either the filter is clogged or the fuel pump isn't working.
Yes, dribbling gas in the carb is dangerous, but so is a lot of stuff you do. Don't ever do it if the engine backfires!! Starter fluid or WD 40 will also work more safely for a few secs.. proving that the engine has spark.
A rusted fuel line would leak eventually... and would be easy to find.
Old trucks are great.
93BetterThanTheRust is offline   Reply With Quote
Old 01-01-2012, 01:54 PM   #7 (permalink)
87 yota
Yea it does spark and turns over when gas is in carburator. I am fixing to put in pump but got to looking at tank and found that there is the pump and then something else that is wired. Is this just a sending unit or what?
Old 01-01-2012, 07:17 PM   #8 (permalink)
out on bail
fourwd1's Avatar
The carbed engine has a mechanical fuel pump, mounted on the engine in front of the carb.
The 2 things in the tank would be the sending unit for the gauge and the fuel pick-up.
There is a site glass in the front of the carb to check the fuel level in the bowl. The level should be in the center.
89 4Runner - stock
Old 01-01-2012, 07:20 PM   #9 (permalink)
out on bail
fourwd1's Avatar
Easy way to check the fuel pump is to disconnect the pump output hose at the carb.
Run the hose into a small can and crank the engine. One quick crank should put a few ounces in the can.
89 4Runner - stock
Old 01-01-2012, 10:42 PM   #10 (permalink)
87 yota
I know I'm not getting gas to the filter so therefore its not getting to carb.....right? If the pump is on the carb then shouldn't. I hear the sending unit come on when cracking?
Old 01-03-2012, 08:58 PM   #11 (permalink)
If the pump is in the tank, then its an EFI or electronic fuel injected. The extra thingy is the sending unit.. which sends the level of gas to your gauge.
The Haynes Manual is pretty good for 79-95 yota pickups. If the fuses and wiring are OK to the best of your knowledge, swapping the pump would be the next likely step.
I'd probably try to bench test it briefly with a 12v supply (carefully..) once it was out to make sure the pump was really dead vs a wiring or electrical problem.
Old 01-04-2012, 08:07 AM   #12 (permalink)
87 yota
Ok guys ....found my fuel problem. It was a clogged filter and I also changed out pump . Now I'm getting fuel but it wasn't firing. Took out plug to check and no spark. Any ideas what to do next.
Old 01-04-2012, 10:18 AM   #13 (permalink)
87yota
Ok replaced distributor cap and rotary button. Still no spark. I have been told it is a possible ignitor or coil. Does anybody have an idea?
