I'm new here. My name is AC. I have a question, and hopefully someone can help me with my problem. My son just bought a used 1984 Toyota Pickup. It was running a rough, and i figured it was in need of a small tune up. I used to own a 1987 Toyota Pickup, with the same 22R, 2.4 Liter engine as this one that my son just purchased. I used to give my Pickup tune ups, oil changes and brake jobs all the time. i even changed the clutch twice. So i thought I had some experience with working on this type of engine today.
I decided to change the spark plugs, distributor cap, rotor, and spark plug wires this afternoon. i felt that did everything correctly. I took each wire off individually, and attached it to the correct plug and to the correct spot on the cap. I felt good about what I did, and when I went to start the truck, it was sputtering and running like it was mis-timing, and it just seemed like it wanted to stall. So, i turned it off and rechecked all the wires and made sure that they were all attached. I re-checked the distributor cap. Everything seemed right, and when I went to start it up again, it wouldn't start. it just kept cranking, but a rough, sputtering type of cranking. But not starting...
What did I do wrong? I'm stumped...
My son is in need of this vehicle to get to and from work.
Please Help!!!
