ya, that motor wont last long with that water mixed in. you've already damaged the bearings, its a matter of time before one starts to spin and clunk or the heat stops working because the magic fix plugged up the heater core, you get hot spots and a warped head/block because the magic fix clogged cooling passages, or it completely overheats because the magic fix clogged the radiator. now, not only willl you need a new engine, but also radiator, hoses, heater hoses, and heater core. amazing what $10 can end up costing isnt it? everyone here said do not use it, and for good reason!
